using mtext string values as a formula to create result field
I am working on creating a grouped item whereby I can take two fields of data (in this case dimensions of a shape) and create a sum using these two values. the equation required would be ((dimA x dimB) x 2.5) x X.
I have attached an example of the current progress but am very much stuck at this point!
I don need the following
  • The number needs to be dynamic and always on show in the position I have displayed it.
  •  I need the number to be round down to 1 decimal point
hoping this is a simple one for the AutoCad genius's out there!
Accepted solutions (3)
Alfred.NESWADBA
please find the attached dwg-file where I have inserted the formulas (at least how I understood the exercise).
Just one note: if you want to use numbers from attributes or text objects as base of calculation don't add units or other characters to that attribute, text, .. as AutoCAD would not be able to handle this as number then.
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2026
(not an Autodesk consultant)
that is exactly what I wanted the object to do! would you mind sharing (by steps) how you select the field in the formula string.
and thank you again, even if I don't understand how it works, it works!
Alfred.NESWADBA
please find that step-by-step video:
- alfred -
Alfred NESWADBA
cadffm
Wherever you are and fields are allowed there: RightClick(contextmenu) -> Insert Field..
Sebastian
Life changing stuff!
thank you so much.
