Using layers as line weights
murphymoon007
Message 1 of 22
murphymoon007
I'm using the student version of AutoCad 2013. I only use it for basic floor plans, elevations, and custom furniture. Line weights are critical to my drawing quality. I've assigned different line weights to different layers; this is the only way I know of to differentiate between line weights. But I can't get the line weights to display at all in Paper Space or when printed.
Replies (21)
Message 21 of 22
kcobabe
Just a note, You do know that you are not suppose to use the educational version for commercial use?  Correct?  Unless Autodesk has changed their view on this.
My suggestion if you are doing this is buy the LT license.  Since what you are doing can easily be done in that package of AutoCAD.
R10 - 2020 ACAD
2008 - 2020 Civil 3D
2014 - 2020 Plant 3D
2014 - 2020 Revit
V8i - V8i SS4 Microstation
Infraworks
2018-2020 Inventor
2020 Navisworks
Message 22 of 22
murphymoon007
Will do. Thanks!!
