General question about polyline vertices
CAD_SNOOK
CAD_SNOOK
Hi All:  I've been on here a bit now and have learned some things and had a lot of fun.  So here's something that bugs me a bit, I'm sure someone can explain and help?
When you hover over polyline vertices you get the popup about 'Stretch'/Convert to Arc', etc.  Why is it that sometimes nothing pops up?  A colleague told me it's because there are 'stacked' vertices there.  You know when you revise and add vertices, stretch things around, invariably some get stacked because no one I know will actually remove the unneccesary ones except me.  Anyway, is that the cause of the above behavior?  And is there a way to get rid of those things?  I think I remember a long time ago I used to edit polylines from the command line and hit 'Next' a lot, then 'Insert' sometimes.  But now that seems old fashioned. And I've never delved any more deeply into it, shame on me...until now!
Any comments?  Thanks in advance!
kcobabe
I believe it could be that or if you have something under it you can get that as well.  Either way just click in the box to find out.
R10 - 2020 ACAD
2008 - 2020 Civil 3D
2014 - 2020 Plant 3D
2014 - 2020 Revit
V8i - V8i SS4 Microstation
Infraworks
2018-2020 Inventor
2020 Navisworks
