USERR1 variable display
info
info
Using Rtext, is there a way to display the value assigned to the USERR1 variable as a 3 place decimal?
cheryl.buck
Autodesk Support
Autodesk Support
Hi @info,
Great question.  There does not appear to be a way to do this directly from the RTEXT command, text formatting appear to be limited to style, height, and rotation.
There may be a way to do this using DIESEL, the members of the AutoCAD Customization Forum would be a great resource for how to do this.
If a post was helpful, Likes are always welcome.
Please click the Accept Solution button for any posts that resolve the issue or answer your question.
All the best,
[This post has been edited for clarity by cheryl.buck]
Cheryl Buck
Technical Support Specialist
Did a post answer your question or help resolve the issue? Please click the Accept Solution button.
If you find a response helpful, consider Liking the post.
info
Thank you, Do I need to repost this to the other forum?
Kent1Cooper
Yes [to the question of whether it can be done -- no, you don't need to post to the Customization Forum].
RTEXT command, Diesel option, put in:
$(rtos, $(getvar, userr1), 2, 3)
The setting of your DIMZIN System Variable will determine whether leading and/or trailing zeros are displayed.  If you change the value, the displayed value can be updated with REGEN.
Kent Cooper, AIA
info
Thank you, that did it.
cheryl.buck
Autodesk Support
Autodesk Support
Hi @info,
Thank you for letting the community know that the info helped. Thank you @Kent1Cooper!
All the best,
Cheryl Buck
