- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Using Rtext, is there a way to display the value assigned to the USERR1 variable as a 3 place decimal?
Hi @info,
Great question. There does not appear to be a way to do this directly from the RTEXT command, text formatting appear to be limited to style, height, and rotation.
There may be a way to do this using DIESEL, the members of the AutoCAD Customization Forum would be a great resource for how to do this.
If a post was helpful, Likes are always welcome.
Please click the Accept Solution button for any posts that resolve the issue or answer your question.
All the best,
[This post has been edited for clarity by cheryl.buck]
Yes [to the question of whether it can be done -- no, you don't need to post to the Customization Forum].
RTEXT command, Diesel option, put in:
$(rtos, $(getvar, userr1), 2, 3)
The setting of your DIMZIN System Variable will determine whether leading and/or trailing zeros are displayed. If you change the value, the displayed value can be updated with REGEN.
Hi @info,
Thank you for letting the community know that the info helped. Thank you @Kent1Cooper!
All the best,
