Use part of layout name in attribute
Can someone point me, or write, field expression so that i can achieve this:
Name of layout: XXXX "1/3"
Attribute: 1/3
I've been looking around and didnt saw anything familiar.
Thanks in advance for help.
vinodkl
Hi @Anonymous
As far as I know, you cannot enter characters like / \ ? : " ; * <> and few more characters in layout name. May I ask how you have entered the "1/3" in the layout name? Can you share a snapshot of the same?
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
Sorry, I didnt check that. I just made up scenario. It could be any kind of numeration for distinguishing lets say "This is drawing one out of three." like Drawing 1.3 ..
How should i edit field expression to achieve that?
neaton
The layout name is contained in the system variable CTAB. Look for the system variables under the fields list dropdown on the left.
Nancy
I know that, but i want to use just part of it... If ctab is DRAWING 1.2,in my attribute i want to use 1.2 only
neaton
Try this link for diesel expression https://forums.autodesk.com/t5/autocad-lt-forum/diesel-expressions-for-layout-tab-names/td-p/7505093
It's not exactly what you are talking about but a diesel expression is probably what you are after.
