I've inherited construction documents .dwgs that have a weird glitch in the anno tags that continues to reappear even after I've replaced them.
Occasional when I open a file a few of the tags will be shifted out of place and at the angle the UCS angle. Sometimes the text of the tag will remain in place but the geometry surrounding it will move. Other instances, like with wall tags the whole tag shifts at said angle.
Please see attached images.
I have tried several commands (annoreset and synchronize multiple scale position) and even replacing the tags by copying others that don't glitch; but over time the same errors the same tags return to this position.
At this office tags are introduced to a file by copying from one file to another. I wonder if that could be an issue.
Any idea as of cause/solution to this reoccuring, ever annoying, issue? Thanks.
