- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi all,
I am learning to use Data Extraction (DX) wizard in Autocad and need a little help please.
I have a block which is a pile that has various information. Northing Easting and various values like live load, dead load etc.. I then use DX Wizard to extract this data into a table. Please see image uploaded here:
At the moment a lot of these values (apart from the co-ordinates) are blank. I would like to fill in this information manually. However I do not want to click on each pile individually to insert it into the "Attributes" box. Now if the values for each attribute (say "DEAD_LOAD") was all the same I could just select all the similar blocks and enter the value for all, unfortunately this is not the case.
Is there a way I can see all my blocks (piles) attributes in a table and edit them like a spreadsheet. Like a reverse DX Wizard if it makes sense. I enter the data in a table and it gets put back into the blocks (piles).
Many thanks in advance
Ernest
