AUTOCAD SAYS UNKNOWN COMMAND "STANDARDS" PRESS F1 FOR HELP
I'm getting this error any one know how to get around this problem ?
when i click on the following menu item i get ---> UNKNOWN COMMAND "STANDARDS" PRESS F1 FOR HELP
http://s13.postimg.org/55gc9hgcn/problem.jpg
Replies (10)
pendean
Community Legend
Community Legend
AutoCAD version?
\Windows version?
Do you already have a DWS file?
What changed recently with your setup or server or office?
Read this post from Autodesk about the topic in genenral:
http://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Error-w...
http://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Error-U...
AutoCAD version?
2013
\Windows version?
windows 7
yes
iv never gone to use this feature, its a work pc so i have no idea the history of the pc
greg_battin
Try putting a period and an underscore before the command
example ._STANDARDS
  • The period before the comand will make the command "redefined" for this instance if it has been "undefined" at some point by someone by using the UNDEFINE command.
  • The underscore forces the command to display prompts in english
~Greg
when i type ._standards this doesn't perform the action i require
what im looking to do is to simply re-name "Layer B" to "Layer A" and have the layer properties changed with out me doing anything when i run check.
so for example  i have a drawing where there are 2 layers
layer a: all lines are dotted, all lines are red
layer b: all lines are white
once i use tool-->cad standards --> configure (which i can't get to work)  to point to the correct dws file then what is supposed to happen when i click the following: tools--> cad standards --> check is the check will look at any object on say "Layer a" and make sure that all lines are dotted and are red
so i could re name Layer b with all the white lines, then once iv changed the layer name to "layer A" all t he layer properties are changed to dotted red lines, once tools--> cad standards --> check has completed
i may make a video explaining what i need if people don't understand what i wrote it seemed complicated to me being a newb
greg_battin
No need to make a video - we understand what you are trying to do. But I'm wanting to know why the command isn't working.
Let me look into it a little more and I will try to help figure it out.
~Greg
greg_battin
Try the following:
ARX <enter>
LOAD <enter>
then browse the default folder which should be "C:/Program Files/Autodesk/AutoCAD 201X/" and look for the .ARX file named "acstd.arx"
After this file is loaded, the Standards command should work. If you can't find it, you can either reinstall ACAD or find someone with the same ACAD version as you and copy the .arx file into that folder.
~Greg
nope its not there see attached
http://s1.postimg.org/emfe79cyn/nope_not_there.png
im going to look for it on another work computer
i found the file you suggested, did the arx thingy see image
how ever now when i go to tools--> cad standards --> configure - i get a fatal error
greg_battin
This may sound crazy - but can you copy all of the .arx and .dll files files from the person's machine and paste them into your folder? Maybe there is another file that this .arx is depending on.
I was simply looking at the .arx file but it does look like there are other files (.dll files) that are needed.
Sorry for the run-around...
