Update Date on a block - Edit Attribute Definition
Message 1 of 8
Good afternoon,
I'm new with Cad drawings and using this forum, therefore, please let me know if I am doing something wrong.
I'm trying to update the date from a block that I am using on a DWG. The problem is that I tried everything that I could find on-line but this field does not update at all.
I tried:
1) The command "updatefield" - it did not work
2) I tried "save as" to see if this field would update - it did not work
3) I also tried "regen" to see if this field would update - it did not work
4) I checked the date using the command "date" - the date is correct
I also tried to select a different "Date format". However, the date updated for "----".
Am I missing something here? Does anybody have any idea?
I am attaching some imeges that may help demonstrate the problem.
Thank you.
Best regards,
Fabio Soares
Replies (7)
Message 2 of 8
TheCADnoob
you can try BATTMAN and ATTSYNC
Or could you try recreating the field?
from my experience once some one has manually changed a field, its toast and reverts to a run of the mill attribute.
CADnoob
Message 3 of 8
john.vellek
Hi @Anonymous,
It looks like you have tried to correct this in a lot of ways. Is it possible to attach the block so I can take a look and make recommendations?
John Vellek
Message 4 of 8
Good evening,
Thank you for the answer.
I attatched one of the DWGs that I am trying to use and update the date.
Again, thank you for trying to help.
Best regards,
Fabio Soares
Message 5 of 8
john.vellek
Hi @Anonymous,
Guess what? It works fine for me.  I opened your block in Block Editor (BE), checked that the field was set correctly (To PlotDate). I then saved the block, plotted the dwg to a PDF and then did a regen. Everything looks fine.
Obviously (without screwing up my own workstation) I couldn't change the date immediately to see how it would update, I did go into the block definition and change the format of the field and repeated the process several times. I noticed that you did have some Proxy Object warnings. I don't think thesee are related to your question but I wanted to make sure that you knew they existed and if intentional great otherwise I would clean them out.
I have attached my copy of the file as well as a video to show you the steps I used.
Please hit the Accept as Solution button if my post fully solves your issue or answers your question.
John Vellek
Message 6 of 8
wispoxy
Hello @Anonymous, run the command FIELD. It must be a system variable or it won't read the same as your computer. Run REGEN if needed afterwards. Any date format is fine.
Use what I showed you in the date blocks or make sure the blocks are using a system varible.
Message 7 of 8
john.vellek
HI @Anonymous,
I am checking back to see if my post or others helped you with your problem. Please add a post with your results so other Forum users can benefit.
Please hit the Accept as Solution button if a post or posts fully solved your issue or answered your question.
John Vellek
Message 8 of 8
Good evening,
The video was helful. The truth is that I was doing the wrong order of steps. After following the video provided, I was able to update the date without problems.
Thank you for your help and support.
Best regards,
Fabio Soares
