Jorge,
I am glad I am not the only one with this problem....Express tools seems to be a
problem sometimes. I have re-installed express tools several times and this
seems to correct the problem. I think your and my problem occurs when you
double click on a drawing file through windows explorer. If you need the
program to work in a pinch use autocads "appload" and load the wipeout routine
manually. You can find it in a directory under ACAD2000 listed as EXPRESS
After that the routine should run through the menu command OK.
If you need more info, email me.
Regards
Brian Marsh
Jorge Carmona wrote:
> I have recently recieved an error Unknown Command when trying to use my
> Express tools. I reinstalled my express tools and still encounter the error.
> What am I missing here? Any help would be appreciatedc.
> Thanks,
> Jorge
> HPI, Inc.
