I uninstalled express tools and reloaded the et2kq100.exe file and now it
works just fine. Doing a search for acetdcp.arx is now successful. Prior
to this the file was missing, even though I had just done a clean install.
If in doubt, uninstall/install, reboot and there you go.
Kent
"Kent" wrote in message
news:B9450DC7B5AAAE21BA4DC60D0A5DE274@in.WebX.SaUCah8kaAW...
> Hi Shaan
> I have a lisp file that loads automatically to turn dblclkedit to off. I
> was using dcprops just fine until I needed to reload the program. So I
> uninstalled Express tools, and A2Ki then reloaded as explained in my
> previous message.
> I didn't receive that error message prior to the uninstall/install. I had
> previously experimented with all the different combinations of dblclkedit
> and dcprops, and never received the acetdcp.arx error.
> I will try uninstalling and reinstalling the express tools. Do you
suggest
> the et2kq100.exe or the
> etv1-9.exe file, I have them both.
> Thanks
> Kent
> "Shaan Hurley" wrote in message
> news:139DD144CE887D19BBBD0978D5EDDFE7@in.WebX.SaUCah8kaAW...
> > Kent,
> > You will get conflicts with DCPROPS in 2000i as the double click edit is
a
> > feature in 2000i. You must disable one or the other.
> > Sincerely,
> > Shaan Hurley
> > Autodesk Beta Programs
> > http://betaprograms.autodesk.com
> > news:CD6A604857D1FAA58579936DB1E6012C@in.WebX.SaUCah8kaAW...
> > > I had to reload A2Ki and express tools and now the Express > tools >
> > double
> > > click properties (dcprops) doesnt work and I get an error message
saying
> > the
> > > acetdcp.arx isn't found.
> > > I loaded A2Ki, then SP2, then Express tools (et2kq100.exe), then
> > Standards,
> > > then XML extensions.
> > > Any help would be appreciated.
> > > Kent Elrod
