AutoCAD Forum
Unit Issues with Another Users File
1 REPLY 1
tellingen
280 Views, 1 Reply
The units on this file measure at 2/3rds of the correct measurements.
A line that is 4' - 0 "  measures at 2' - 8".
I have changed the units to Architectural 1/4" = 1'.
The file was developed in Engineering scale.
I believe I should be able to change these units by changing the scale.
Is there another setting that needs to be changed as well?
I've attached the file and a screen shot of one area that should measure 4' - 0".
The entire files measures at 2/3rds of the correct size.
Any information would be very appreciated!
1 REPLY 1
Alfred.NESWADBA
in reply to: tellingen
Then use command _SCALE and use option _REFERENCE (reference length is then the line's startpoint to endpoint and destination length is 4' 0").
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2024
(not an Autodesk consultant)
AutoCAD Inside the Factory
