2017 Object Snap stopped working after Windows update...
All was working fine with Object snap now all of a sudden it has stopped working. The only changes to the system have been form Windows updates but I can't find the correct one or know how to track it down.
Happens on new drawing with just basic line segments.. I've scoured the internet and tried a number of suggestions but no luck, pretty sure this is an OS problem and not a setting issue.
Anyone have any ideas?
When performing a Linear function I do get Snaps???  So, maybe it's not PC related??
RobDraw
Correct.
What settings related to OSnaps have you checked and what are their values?
Rob
I've tried resetting to Default, changing marker size, verified color.. etc. seems like all the basic stuff but since I didn't make any changes to those items I feel somehow that it's related to an OS update???
see attached for current settings..
RobDraw
If it were, there would be more posts about it. Have you restarted the computer since your issue started?
Your settings look correct as long as you are using OSnap Tracking. If that got turned on accidently and you are unfamiliar with using it, it can get in the way of OSnaps working as expected.
If that is on purposely, you are going to have to explain your issue more clearly. You started off saying that they aren't working and later said they seem to be working partially.
A screen cast showing the behavior would be extremely helpful.
Rob
Thanks, I'll see if I can get a screencast of the problem and post back.
RobDraw
What about the other two things that I asked about?
Please include that information also.
Rob
