Uninstall still leaves all files in c:/program files/Autodesk?
mail
mail
After uninstalling the Building Suite in Control panel, I've noticed that all files are still showing in c:/program files/Autodesk and there is 12gb of them. How do I delete these? Do I simply choose the folder and click delete?
swieciakpawel
Hello and welcome to Autodesk Forums,
If You don't have any other Autodesk application left, that can be uninstalled through Control Panel, then You should be free to clean up everything that can be still found on Your computer without worries. If You want to be sure that You got rid of everything, keep in mind that some files might be also in other locations, for this I recommend this Article - Clean Uninstall.
Considering the size of the folder that You mentioned, it might be possible that You have old installation files located there or some other applications, but there should be no problems if the aforementioned condition is met.
Kind Regards,
Pawel
mail
Thanks Pawel, I'll look at that.
