Problem with ATTEDIT failing to update attribute values
I normally use ATTEDIT rather than EATTEDIT, as it is much quicker for changing multiple attributes in blocks.
However, I am finding it is intermittently failing to update blocks. If I double-click the block, or start the command from the command line, the ATTEDIT window opens normally and I can change the attributes, however no changes are made to the block on clicking OK. No error message is generated. However EATTEDIT is working normally, and if I insert a new block, it will generally work normally with both commands.
In the attached drawing I cannot update the level blocks with ATTEDIT. But the new block (in the rectangle) is fully editable with ATTEDIT.
This issue is not specific to particular blocks or to particular drawings.
I am using Autocad 2018 (2018.0.2) and Win10.
