Stray lines in display with AutoCAD 2018
2018 autocad installed and everytime i open a drawing i get these lines running through the drawing any ideas on whats going on?20170509_135418[1].jpg
@Anonymous,
john.vellek has edited your subject line for clarity: autocad 2018
Alfred.NESWADBA
turn off your hardware acceleration (command _GRAPHICSCONFIG).
If that helps you might play with the options of that dialog or update your graphic card driver.
HTH, - alfred -
Alfred NESWADBA
(not an Autodesk consultant)
john.vellek
HI @Anonymous,
I see that you are visiting as a new member. Welcome to the Autodesk Community!
 If you open GRAPHICSCONFIG, turn off the Smooth Line Display
That should correct the display issue you are having. After that, you might check to see if a newer graphics card driver is available for your system.
John Vellek
john.vellek
Hi @Anonymous,
I am checking back to see if my post or Alfred's helped you with your problem. Please add a post with how you decide to proceed and your results so other Community members may benefit.
Please hit the Accept as Solution button if a post or posts solves your issue or answers your question.
John Vellek
