Uniform pattern
Uniform pattern
I am using path array option for draw the below pattern. But, there is no uniform pattern of the drawing as shown below.
The path has two lines as shown in image.
I want to fill the pattern uniformly in between two lines.
Thank in advance
imadHabash
click on below image and see how SUPERHATCH (Express Tool) will serve you (prepare your block first) . >> Click <<
Imad Habash
dbroad
Assuming you're trying to tile a curved sidewalk, for the best pack, use a rectangular array, not a path array, to tile the circles.  Then adjust the y axis to 60 degrees for a the tightest pack.  Then convert the two curved boundaries into a single closed polyline with all straight segments. Then clip the array with the new polyline.
Architect, Registered NC, VA, SC, & GA.
