AutoCAD Forum
Uniform pattern
2 REPLIES 2
296 Views, 2 Replies
Uniform pattern
I am using path array option for draw the below pattern. But, there is no uniform pattern of the drawing as shown below.
The path has two lines as shown in image.
I want to fill the pattern uniformly in between two lines.
Thank in advance
2 REPLIES 2
imadHabash
click on below image and see how SUPERHATCH (Express Tool) will serve you (prepare your block first) . >> Click <<
dbroad
Assuming you're trying to tile a curved sidewalk, for the best pack, use a rectangular array, not a path array, to tile the circles.  Then adjust the y axis to 60 degrees for a the tightest pack.  Then convert the two curved boundaries into a single closed polyline with all straight segments. Then clip the array with the new polyline.
Architect, Registered NC, VA, SC, & GA.
Technology Administrators
AutoCAD Beta
