Unexplodable Blocks
Unexplodable Blocks
muzaffarhabibjonov
Unexplodable Blocks
muzaffarhabibjonov
Hi, I cannot unblock my drawings, it's unitless seems, may be for this reason I cannot select object when I use Explode command, how to explode, please help to fix my file
Kent1Cooper
If you BEDIT a Block, there's an entry in the Properties palette about whether or not it is Explodable.
Kent Cooper, AIA
muzaffarhabibjonov
Entered BEDIT command, still cannot be exploded even inside of the block, can you please ckeck out the file
imadHabash
You have a Minsert blocks .. You can not explode it directly. You may need an outsource lisp or plugins to fix your blocks. For more info follow these links >> Click <<  >> Click1 <<
Note: In some cases you can fix the issue by using ‘FLATTEN’ command then 'EXPLODE' command.But you may get undesirable results.
Good Luck..
Imad Habash
muzaffarhabibjonov
Thank you, worked)
