Unexplodable Blocks
muzaffarhabibjonov
Unexplodable Blocks
muzaffarhabibjonov
Hi, I cannot unblock my drawings, it's unitless seems, may be for this reason I cannot select object when I use Explode command, how to explode, please help to fix my file
0 Me gusta
Responder
Soluciones aceptadas (1)
844 Vistas
4 Respuestas
Respuestas (4)
Kent1Cooper
If you BEDIT a Block, there's an entry in the Properties palette about whether or not it is Explodable.
Kent Cooper, AIA
0 Me gusta
muzaffarhabibjonov
Entered BEDIT command, still cannot be exploded even inside of the block, can you please ckeck out the file
0 Me gusta
imadHabash
Solución aceptada
You have a Minsert blocks .. You can not explode it directly. You may need an outsource lisp or plugins to fix your blocks. For more info follow these links >> Click <<  >> Click1 <<
Note: In some cases you can fix the issue by using ‘FLATTEN’ command then 'EXPLODE' command.But you may get undesirable results.
Good Luck..
Imad Habash
0 Me gusta
muzaffarhabibjonov
Thank you, worked)
0 Me gusta
