- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Since I've upgraded from AutoCAD 2020 to AutoCAD 2021, I've been unable to plot A1/A0 drawings to the HP plotter.
I have 2 direct connections to the plotter & 1 through the server, none will plot the any/the whole drawing.
The server connection, I have been through the printer properties numerous times, but I can not get it to plot more than an A4 section of the top corner.
The direct plot connections, I'm unable to plot & get told "The selected layout has an invalid media configuration" so I have to change to either none or regular (depending on what it was set to previously) in the Media Destination, then the plot is plotted in landscape when the paper is portrait, so the title box is lost. I've change the properties to rotate 90deg but the same issue happens with everything I try.
I've migrated my 2020 settings again, but it makes no difference.
When I need to plot, I have to go back to 2020 to plot as this still works as it should & did.
