Unable to detach the xref in the file
madhuryya_prakash
Message 1 of 9
madhuryya_prakash
Hi All,
Have been trying to detach the x-ref file from the parent one.  Tried different ways to remove it, but unable to do so. Any help would be of great use.
Replies (8)
Message 2 of 9
K_Kubat
The reference is probably located in a block, so it can't be resolved.
According to my research, the reference is located in the "window 05" block.
Open it in the block editor and delete the reference there, or resolve the block to its original location to resolve the reference.
Message 3 of 9
pendean
Community Legend
Community Legend
Your XREF is inside something else in your file, so the posted DWG file is not the "parent", and XREF command by-design will not let you detach it 'remotely'.
What does the XREF "Purva Westend 2_1ST FLOOR PLAN_WD" look like?
Message 4 of 9
madhuryya_prakash
Well, I have lost the file "Purva Westend 2_1ST FLOOR PLAN_WD"
Message 5 of 9
paullimapa
Just create a new blank dwg with that name and save it in the same location. Now you can reload that and detach it.
Paul Li
IT Specialist
@The Office
Message 6 of 9
vinodkl
Hello @madhuryya_prakash
Begin by creating a blank drawing. Then, open the drawing from which you are unable to detach the XREF. Type XREF to open the External References palette. Locate and select the XREF that is causing the issue. Update its saved path to point to the blank drawing you created earlier—this will allow the XREF to load successfully. Once loaded, right-click on the XREF and choose Bind. Image for reference.
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
Message 7 of 9
madhuryya_prakash
Toomba thanks Vinod avaru. 🙂
Message 8 of 9
paullimapa
Did you try a similar solution I had posted earlier in msg 5:
https://forums.autodesk.com/t5/autocad-forum/unable-to-detach-the-xref-in-the-file/m-p/13604223/high...
Paul Li
IT Specialist
@The Office
Message 9 of 9
vinodkl
@madhuryya_prakash Kannadalli nimma uttara nodi thumba kushi aythu 😀(Happy to see your reply in Kannada 😃)
