I'm quite new to autoCAD, but I'm trying to convert 3 areas to regions, I've managed to convert 2 of them but for some reason I can't convert the last one. What am I doing incorrect?
Solved by tramber. Go to Solution.
You should learn about polylines and draw with them, to my opinion.
However, you should use the BOUNDARY command, it works with your purpose.
If you use the REGION command with objects that intersects badly or are one over the other one and so one it is not good.
I will have a look on your dwg now 😉
