AutoCAD Forum
Unable to convert to region
3 REPLIES 3
elfiS4WQQ
287 Views, 3 Replies
I'm quite new to autoCAD, but I'm trying to convert 3  areas to regions, I've managed to convert 2 of them but for some reason I can't convert the last one. What am I doing incorrect?
Tags (1)
Labels (1)
3 REPLIES 3
tramber
in reply to: elfiS4WQQ
You should learn about polylines and draw with them, to my opinion.
However, you should use the BOUNDARY command, it works with your purpose.
If you use the REGION command with objects that intersects badly or are one over the other one and so one it is not good.
I will have a look on your dwg now 😉
tramber
Overlapping :
Same on the right 😉
elfiS4WQQ
in reply to: tramber
Thank you for your input! That worked wonders 🙂
Forma Design Contest
