UCS
UCS
UCS
We have an error message when we rotate the attributes
I tried different ways to approach the parallel ways.
Example:
Flatten,
Can you provide me the best solution for this?
Thanks in Advance
Best regards,
Sujitha Arivazhagan
lucdoucet_msdl
The problem you are describing is Autocad related and this forum is for FormIt.
This said, when Autocad entities are drawn in a different user coordinate system (UCS), some commands won't work if you are in a UCS which is rotated at a perpendicular angle to the objects UCS.
You can set the current UCS to match an entity with the command : UCS, option E for byEntity and select the object. Then when the UCS is set, try your command again.
Hope this helps,
-luc
S.Faris
What is your current UCS setting? If not world, did you try changing it to World and then use TORIENT? Is any of the elements created with a custom UCS?
Could you share the file here?
SALMANUL FARIS
