Is there an automatic way to align the UCS to the NavCube when selecting Front/Back/Right/Left arrows on the NavCube? Right now when I select the arrows to rotate my model view the UCS stays aligned with the WCS and I have to enter UCS then V(for view) to make the X/Y orientation a "plan" view to work in that view.
looks like this has been asked before:
https://www.reddit.com/r/AutoCAD/comments/k0tdyq/can_the_coordinate_system_ucs_follow_the_viewcube/
Sorry I forgot to mention I tried UCSFOLLOW, UCSORTHO, and
None of those work.
I usually do not go to Reddit for any answers I trust. But I have the same setup already and i was looking for a better solution.
@BSchwartzkopf Start here, see if you get ideas from it
https://forums.autodesk.com/t5/autocad-forum/want-ucs-to-follow-view-changes/m-p/5882821#M101537
And this tool, with limitation, perhaps the author can help you develop it further
https://www.cadforum.cz/en/automatic-ucs-aligned-with-the-current-view-tip11847#google_vignette
