‘\U+0020’ as a space in AutoCAD attribute going into Vault
warrentdo
Message 1 of 12
warrentdo
Hello All,
Just before I start testing has anyone had any experiences of using ‘\U+0020’ to mimic a space when using it in the property name of an AutoCAD block that will be mapped to vault?
Has using ‘\U+0020’ caused any other issues that you are aware of?
Warren.
Replies (11)
Message 2 of 12
pendean
Community Legend
Community Legend
Test it.
Message 3 of 12
paullimapa
Question: Why would you need another character to mimic a space?  Does Vault not support spaces in block names in AutoCAD?
Paul Li
IT Specialist
@The Office
Message 4 of 12
warrentdo
Before I test it I was looking for any other isues that I may come across later down the line. I was trying to look for help and use the experience of the group. There is no point testing if there are known issues.
Message 5 of 12
warrentdo
Hello, this is not a space in a block name, but a space in a property name which i believe that AutoCAD will not. Vault will except spaces in both.
Message 6 of 12
paullimapa
Here's a screenshot showing the Properties of a Block in AutoCAD. Some of these Properties shown obviously cannot have a space like Scale X, Y & Z.
But a number of the Properties do support a space in AutoCAD. So which of these Properties are you referring to that currently cannot have a space and you want to replace with \U+0020’?
Paul Li
IT Specialist
@The Office
Message 7 of 12
warrentdo
Hello, these will be custom properties. 'Room Number' 'Area Type' etc.
Message 8 of 12
paullimapa
How do you add custom properties to a Block in plain AutoCAD?
Paul Li
IT Specialist
@The Office
Message 9 of 12
warrentdo
ATTDEF. the property name is represented by the TAG name.
Message 10 of 12
cadffm
so we speaking about simple ATTRIB tags
Okay.
You are right, Spaces are not allowed [F1] ATTDEF
But by programming, it is possible to do that for existing (blockreference)attributes.
Back to your U+0020 Question: THIS WORKS on Acad side. (Note: I didn't test all functions, but it works generally)
Sebastian
Message 11 of 12
cadffm
I guess, near to nobody have expierence with that (perhaps I am wrong and for Vault users it is a common workareound),
because it sounds a bit crazy (I would never do that)
For usual you should use UPPERCASE chars withour special characters for Attdes/Attributes.
I tested (and it works):
EATTEDIT
DATAEXTRACT
FIND
properties-palette to change ATTRIB value
ATTOUT/ATTIN
REFEDIT
BEDIT
ATTSYNC
Failed:
BATTMAN
properties-palette to change ATTDEF tag
ddedit  to change ATTDEF tag
Now it's an you or others, to check each single function.
Sebastian
Message 12 of 12
warrentdo
I agree that the naming convention is crazy, but unfortunately im being forced into this.
