Turing Text into a Hatch
Message 1 of 9
I would like to know if it is possible to turn a text into a hatch. An example is branding on bubble gum wrappers. If it is possible, how do i do it?
THANKS!
Replies (8)
Message 2 of 9
Kent1Cooper
Look into the SUPERHATCH Express Tool.
Kent Cooper, AIA
Message 3 of 9
I am not sure. I don't think you can do it.
Message 4 of 9
TheCADnoob
IF this is a one off type deal i might use array and express tools to 'simulate' a hatch. I this video i array the text then i explode the array and explode the text using express tools. It takes a few mins to clean it up so like i said if this is a one off thing it might work but i would look into other solutions if this is something you will be doing with any kind of regularity.
CADnoob
Message 5 of 9
nrz13
http://forums.autodesk.com/t5/autocad-2013-2014-2015-2016-2017/outlined-text/m-p/6205653/
Work:  AutoCAD 2022.1.3, Windows 10 Pro v22H2 64-bit, Intel Core i7-8700K, 64GB RAM, Samsung 960 Pro SSD, AMD Radeon Pro WX 5100, 3 Dell Monitors (3840x2160)
Home: AutoCAD 2022.1.3, Windows 10 Pro v22H2 64-bit, Intel Core i7-11700, 64GB RAM, Samsung 980 Pro SSD, NVIDIA Quadro P2200, Dell Monitor (3840x2160)
Message 6 of 9
JasonArtley
Assuming you're using a solid text like Arial, you can use the "Explode Text" command under the express tools (or type "txtexp"). This will remove the solid fill from the text and provide solid boundaries for easy hatching.
Message 7 of 9
nrz13
@JasonArtley
That will still leave the characters broken and require many hatch fill points.  See my link above for the full solution, where creating a REGION and UNION of the text will allow you to fill the entire object at once with Hatch > Add: Select Objects.
Message 8 of 9
john.vellek
Hi @Anonymous
I took your question and decided to illustrate some features with a Screencast video for you.
I start with a piece of text and use the Express Tools- Explode Text to get the outlines. (It isn't very clean but will get the concept I think).
Next I turned the outlines into a single block.
Next, with Express Tools- SuperHatch I use the block to create my hatch pattern for my gum wrapper.
Please select the Accept as Solution button if my post fully solves your issue or answers your question.
John Vellek
Message 9 of 9
john.vellek
HI zbriguglio,
I am checking back to see if my post or others helped you with your problem.
Please add a post with your results so other Forum users can benefit.
Please select the Accept as Solution button if a post or posts fully solved your issue or answered your question.
John Vellek
