I've downloaded AutoCAD 2016 student version. After instalation it has opened correctly but I can't start it again. What the program does is sturting up until create/learn window. I can swith beetween this two options. I can choose a template of my workspace from a dropdown menu but when I click start drawing(it changes color) nothing happen. I can't minimize the program window neither change it to window mode. My PC configuration meets the requirements
Piotr Maryańśki
Solved by pendean. Go to Solution.
I've done reset - still locks up.
I've opened AC as an administrator, as a normal user - no difference at all.
I'll just add that I can watch learn movies, I can choose the template. Some things work fine but I can't create nor open existing file. I click and nothing happens. It's weird because if a program does not respond it shouldn't respond at all but in the case I can do some things with AC
Any other Ideas?
Hello again,
The problem appears every time I want to open autocad. I need to restart PC and reset Autocad. It's really annoying. Do you have any tips what can I do to prevent AC from crashing?
Piotr Maryański
