Announcements
Trying to find the Object or Entity using one Annotative Scale
MatTheDrafter
MatTheDrafter
I’m attempting to clean up every single annotative scale used in our series of CAD drawings that haven’t been well maintained for ten years. I keep running into situations that there is one Annotative Scale that I can’t delete since I can’t locate which object, block, or entity is using that scale. I have used properties menu and searched selection type and find what could be using the annoying annotative scale and deleting and replacing it when possible.
I am hoping someone knows of a similar way of doing this. I do recall there was a command that globally allowed you to apply whatever Annotative scale you wanted to all selectable objects. Is there a command that will allow you to remove a scale globally?
Replies (9)
Alfred.NESWADBA
I would create a new layout, one viewport, thaw all layers and make this one anno-scale active for that viewport (make sure ANNOALLVISIBLE is not active). All objects that might be annotative (like block, hatch, dimension, text, mtext, leader) are now visible if they have this annotation scale assigned.
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2025
(not an Autodesk consultant)
murray-clack
I found a routine online that will highlight all objects based on an [unwanted] Annotative Scale that you enter (e.g. "1:1_1")
Load the routine and enter the command SBAS, you will then be prompted to enter the annotation scale by hand
(FYI - 3 out of 5 times, it is usually a piece of associative hatch patterns)
MatTheDrafter
Okay, I have done the LISP routine and made the viewport suggestion. I am still unable to purge the Annotation Scale "1:1000".
I've attached a copy of the CAD file that I am trying to clean up. I had to delete the data that we are not supposed to share out.
I hope someone can assist me in figuring out how to remove that scale and the steps on how they may have done it.
T
Alfred.NESWADBA
these 2 scales are special ones as you can't edit their details, both are set to 1 and 1 in the dialog and none editable.
So that might now be the reason why they can't be removed.
I tried then to save the dwg-file as DXF, removed the "1:1000" scale from the DXF and opened the DXF. The first disadvantage was that _AUDIT found now a lot of defect block names (names starting with *A), so I decided to look to blocks in general and it seems like there went something wrong, seeing so many grip points outside the geometry itself:
You might try to continue with the file I have got after DXF saving, manual editing, then _AUDIT ... but I'm not sure to have all objects like you had it, the mass of audit messages does not sound great.
- alfred -
Alfred NESWADBA
murray-clack
I got it to work..
Here's the trick:
1. I deleted the 1:1 annotation scale (it wasn't assigned to any objects)
2. I renamed the 1:1000 as "1:1" (both the 1:1000 & 1:1_1 have the same values)
3. I assigned all the objects to have the new "1:1" anno scale
4. I deleted the 1:1_1 anno scale from the objects and from the anno list so that only the 1:1 scale is left in the drawing
MatTheDrafter
I think I will have to use the .dxf solutions to all these drawings. Once I followed that process I was able to purge additional text styles and line types that I have been trying to clean up for a few months now.
JuLoVe
Lately i've found this kind of problems and i could not solve them neither going the lisp way nor dxf.
By modifying my dwg, using WBLOCK on it and changing the UNITS on the file, the dwgunits and the INSUNITS several times ive got two thins, i got rid of one of the "bug" scales and in other dwg i managed to not have a 1:1_1 (saying 1:0.001) but a second 1:1_2 (1:1e-6) that wasnt even there in the beginning, so i think it may be some bugging in the units of the drawing that you can amend by reinserting the drawing and fidgeting with the dwg units in some random way.
Edit: Yeah, by turning the drawing into a block, changing the units from mm to metres (i switched it to mm to try to fix the problem and that is how i got my second instance of undeletable scales (1:1e-6 as 1:1_2). So going back from mm to metres turned "magicly" the block into unitless and removed one of the buggy scales.
JuLoVe
Edit: Nothing, it was not fixed. It is like if the file wasnt comfortable with the scale we use...
cadffm
Rule1
You can not delete the first scale,
the first scale is in standard setup 1:1 and the definition is 1:1
You can rename it
You can redefine it
But is it still the first
Rule2
Don't touch default scales,
create your own with well names.
Acad create renamed copies if you your create(/import) scales with the same name, but with another definition.
Thats all you need to know, it should explain all things.
Otherwise upload a small sample(dwg) and explain how to recreate your issue.
Small dwg means just few objects.
Sebastian
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
