AutoCAD Forum
Trueview - No Commandline?
11 REPLIES 11
Message 1 of 12
mthomas
66232 Views, 11 Replies
I have no commandline in my TrueView... how do I get it back? help!
Mike Thomas
Tags (2)
11 REPLIES 11
Message 2 of 12
pendean
in reply to: mthomas
Trueview forum is here: http://forums.autodesk.com/t5/DWG-TrueView/bd-p/109
CTRL+9 toggle it on and off, just like AutoCAD: or TOOLS menu bar, Commandline option. Forgot to turn on the menubar? Do so by clicking on the very small arrow down at the end of the very small row of icons nex to the big blue D and select SHOW MENU BAR.
Message 3 of 12
mthomas
in reply to: pendean
Of course that would work... doh!. I got flustered because I couldn't type COMMANDLINE
Mike Thomas
Message 4 of 12
I lost my command line when moving it and can't get it back. control 9 does nothing
anyideas...very new at this so be easy
thanks
Message 5 of 12
pendean
Message 6 of 12
Have you gotten an answer to this? I have the same problem. Although a portion of the command line is on screen, it is the portion you can do nothing with. Help! The tip listed above does not work. The other tips are for Autocad, not Trueview.
Message 7 of 12
pendean
Answers are posted: are you having a particular problem?
Message 8 of 12
Answers do not work in Trueview 2014.
Message 9 of 12
pendean
The solutions posted are application-neutral: they work with most apps.
So what exactly is your issue? It probably is not the same as The one the solution the user above identified.
Also: you are posting in the wrong forum for your software product: see post #2 above.
Message 10 of 12
The tip does not work for the command line retrieval in Trueview 2014. You can move the Trueview window itself, but the command line window is not anchored to this window at all. No part of the command line window that is visible can be moved. I picked Trueview from the apps. Any other suggestions? Appreciate the help. I suppose I could re-install, but I would lose my customizations, which is some work.
Message 11 of 12
pendean
Customizations in DTV2014? And what do they do if I may ask?
Maybe they pushed it off screen for you? DTV forum is over there http://forums.autodesk.com/t5/DWG-TrueView/bd-p/109, not here.
Message 12 of 12
darragh1
Had same thing happen me..
Try this.
CTRL+9. if this does not work go to top of screen and check top toolbar if menu bar is visible.
If not make it visible.
Then go to tools and you can select it on or off from here
Hope that works as did for me
Forma Design Contest
