I've noticed a couple of things I cannot do in 2016 that I could with release 2000. The first thing is that I cannot extrude an object by selecting two points on a different solid. I used to be able to specify the distance to extrude by selecting 2 endpoints. Now I have to actually measure the distance and type it in or move the profile to the endpoint of the other object and select the 2nd point.
The other issue I am having is that I cannot select the midpoint on the edge of a solid when i have the lines hidden. I can only pick the midpoin of the entire solid.
I am trying to draw a construction line across the face of a cube from the midpoint of one side to the midpoint on the other side.
