trouble when object is hidden
I've noticed a couple of things I cannot do in 2016 that I could with release 2000. The first thing is that I cannot extrude an object by selecting two points on a different solid. I used to be able to specify the distance to extrude by selecting 2 endpoints. Now I have to actually measure the distance and type it in or move the profile to the endpoint of the other object and select the 2nd point.
The other issue I am having is that I cannot select the midpoint on the edge of a solid when i have the lines hidden. I can only pick the midpoin of the entire solid.
I am trying to draw a construction line across the face of a cube from the midpoint of one side to the midpoint on the other side.
Alfred.NESWADBA
When you were asked to enter a value or an option (Direction/Path/Taper) you can use
(getdist)
That asks you for 2 points and returns the distance as result to the command.
Why hiding lines when you need them to show the mid point? You will be unsure what mid-point you show.
BUT: I can use the midpoint objectsnap while I'm in visual style "hidden":
Then use objectsnap _ZCEN and you will get that:
So all is well, just to learn new features 😉
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2026
(not an Autodesk consultant)
Thank you Alfred!
Alfred.NESWADBA
You are welcome! - alfred -
Alfred NESWADBA
