error autocad 2005
error autocad 2005
error autocad 2005
Hi, for some time every time I open a file autocad will read error while sending the command to the program.What does it means and what is the solution? Thanks a lot
pendean
Community Legend
Community Legend
What changed on your PC recently?
Hi, After you upgrade your operating system to Windows 8.1 pro I had to
uninstall and reinstall the program. From there after the error occurs,
and I don't know how to solve it.
Thank you very much
wispoxy
Hello @Anonymous and Welcome to the Autodesk Community!
1 - http://www.longbowsoftware.com/
2 - Run a VMWare with Win 2000+SP4 32 bits or Win XP Pro 32 bits
3 - Try to use the special "Win XP Mode" of Win Seven/Eight
Very often, they are some problems and it's very slow !
#Steps above provided by @braudpat
Longbow Instructions
  1. Obtain your copy of the Longbow Converter here
  2. Copy your AutoCAD 2005 CD to your hard drive, to a folder path c:\Autodesk\acad2005
  3. Start the Longbow Converter tool, select the 2nd tab, pick the c:\Autodesk\acad2005 folder, and click Run. Read and understand all the prompts before pressing OK. Once the setup starts, stop and read the next step…
  4. In the setup program, navigate through each setup dialog as normal, except when you get to the installation folder, **it’s vitally important to make sure you install to c:\acad2005 (not Program Files (x86)\AutoCAD 2005**
  5. If you see an error in install “.NET Runtime Optimization Service has stopped working” – simply ignore by clicking the “Close Program” button
  6. When a message box appears warning that “64bit .NET Unavailable” – simply click OK to carry on and install AutoCAD as normal – this does not affect anything.
  7. Once installed, go back to the Converter tool, select the 3rd tab, pick the newly installed c:\acad2005 folder and click Fix.
  8. Now you can run your AutoCAD 2005, but it’s a good idea to install the latest service packs.
  9. NOTE: If you see a warning dialog when you run saying “This program has known compatibility issues”, simply click “Don’t show this message again” and then click “Run the Program…”
Installing AutoCAD 2005 Sp1
To install the sp for your AutoCAD…
  1. Download your specific language version of AutoCAD 2005 Sp1
  2. Copy the service pack exe installer to folder path c:\Autodesk\sp
  3. Start the Converter, select the 3rd tab, pick the c:\Autodesk\sp folder and click Fix.
  4. Now run the service pack exe installer from Windows explorer
  5. NOTE: If your AutoCAD now fails to start, you may now need to again re-run the Converter process from step (6) above
Troubleshooting:
If you are unable to activate your product, or the activation crashes:
If you have crashing problems using the File->Open or File->Save dialogs inside of AutoCAD please read this blog entry on the File->Open or File->Save Crash in AutoCAD
Copyright 2015 (c) Longbow Software
