Trim tool not working
When I try to use the trim tool, it extends the line or does not trim to an intersection? it only offers to extend or trim say 60% of that line?
Replies (11)
imadHabash
I suggest to try change mOde while TRIM command is active  Mode=Standard .
Imad Habash
Hi, does this mean trim mode = 0 ?
imadHabash
Your issue is related to trim command as you said ... Select object to trim or shift-select to extend . So be sure that you're not pressing Shift while Trimming .
Imad Habash
Ive tried this. I am not holding shift. I select trim, hit enter to trim freely. I have attached a video to show the issue
user181
For the issue of only trimmimg 60% of the line try setting EDGEMODE to 0
imadHabash
Thanks for your video ... can we have the same part that you have tested in the video as .dwg file for testing please ?
Imad Habash
Sure. please see attatched file.
pendean
Community Legend
Community Legend
Your drawing is way way too far away from 0,0,0 in your file: that's your problem.
Move your content back to near 0,0,0
Just tried this, didnt make a difference for me?
Kent1Cooper
@pendean wrote:
Your drawing is way way too far away from 0,0,0 in your file: that's your problem. ....
How far away, you may ask?  About 34 times the distance from the Earth to the Moon.
If it has all been moved closer to the origin [which worked for me], and it didn't fix the problem for you, post your version of the revised drawing.
Kent Cooper, AIA
pendean
Community Legend
Community Legend
@Kent1Cooper I posted the file I fixed, all the weirdness with grips not showing + TRIM works fine after the move in R2021.1 and R2020.1.2.
@Anonymous Try the file I posted, no issue there for me. BTW, have you considered using XREFs?
Type a product name
