Trim surfaces works in copied objects only
I want to find the intersection of the oval yellow surface with the white planar one.
I used Trim surfaces command (on the Surface tab) but i don't see a change.
I copied the 2 surfaces to an empty drawing and there the cut was.
I repeated that and the same: in the original drawing, cleaned and attached here, they exist both complete (the drawing's name is Space Ship), and the Test drawing is with the copied surfaces.
Why don't i see the change in the original drawing?
