can't save as
can't save as
Message 1 of 15
can't save as
when I use save as in AutoCAD the computer stock. the problem is solved when repair install just for the first run then stock again. I think it is a virus how can find the virus which prevents autocad from saving or block it if antivirus was not slove the problem.
thanks
Accepted solutions (3)
Replies (14)
Message 2 of 15
pendean
Community Legend
Community Legend
Your AutoCAD version is...?
Your WIndows version is...?
Where are you saving files to exactly?
Message 3 of 15
john.vellek
Hi @Anonymous,
If you feel this is a security software that is blocking the SaveAs, try rebooting in a diagnostic mode (msconfig). Turn everything off and reboot. If AutoCAD is happy then it is likely one of the application that get loaded at startup and you can re-enable them one at a time until you find the culprit.
John Vellek
Message 4 of 15
imadHabash
>> I think it is a virus  ....
and maybe NOT .
does this problem just lately appeared ?
does it happened in every CAD .dwg file or just in a certain one ?
if you make a new drawing saved on your Desktop place ... any changes ?
Imad Habash
Message 5 of 15
autocad 2009 $ civil 3d 2011
cant reach to dialg box save as ... the computer stock and the restart
computer
Message 6 of 15
john.vellek
HI @Anonymous,
Are you saying that you just don't see a dialog box when you want to perform a Saveas?
Set your FILEDIA=1 and see if that corrects the problem.
John Vellek
Message 7 of 15
pendean
Community Legend
Community Legend
Message 8 of 15
in all dwg files
Message 9 of 15
no computer stock and need to restart
Message 10 of 15
vtkong.com
Command: FILEDIA, Enter 1 will help you solve this problem
Message 11 of 15
Same problem
FILEDIA =1 works! problem solved!
Thank you
Message 12 of 15
vtkong.com
You can copy the file to and open a new file to try saving
If not, you can use the Dxfout command
Or the audit command, choose Y
Message 13 of 15
michaelmbgr09
This worked for me, thanks
Message 14 of 15
yreyesYJAU4
Community Visitor
Community Visitor
Changing the FILEDIA to 1 fixed my Save As problem in AutoCAD Electrical
Message 15 of 15
Problem Solved...
