Trim surfaces works in copied objects only
Karol-Or
Karol-Or
I want to find the intersection of the oval yellow surface with the white planar one.
I used Trim surfaces command (on the Surface tab) but i don't see a change.
I copied the 2 surfaces to an empty drawing and there the cut was.
I repeated that and the same: in the original drawing, cleaned and attached here, they exist both complete (the drawing's name is Space Ship), and the Test drawing is with the copied surfaces.
Why don't i see the change in the original drawing?
john.vellek
Hi @Karol-Or,
I set the UCS to World and then performed slice using the white surface. It appears to work fine for me unless I misunderstood your question.
John Vellek
imadHabash
the problem is with SURFTRIM command . it's not applicable in her Space Ship 2 .dwg file but it's OK when copied to another .dwg file !!
Imad Habash
Karol-Or
Which command did you use for slice. i use 2013
imadHabash
SLICE command .
Imad Habash
john.vellek
Hi @Karol-Or,
Did you have any luck with SLICE?  I tried the surftrim on new geometry in your file and that did not work either.  Audit does not see any errors but there is obviously something wrong with the dwg.
John Vellek
