Trim command working indifferently
vinodkl
Mentor Mentor
Message 1 of 9
vinodkl
Trim command not working the way it was working earlier. It works properly when a single selection is made but its trimming little extra when crossing is used. Below is the snapshot of the same which shows what I am talking about. I also tried edgemode=1 still no use. Any help will be appreciated.
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
Replies (8)
Message 2 of 9
jayhar
set the drawing's UNITS to Decimal and set the Precision setting to 8 places after the decimal point
Please Mark the Post or Posts as Solution(s) to help others find the answer quickly. If your issue persists,
Please give me a bit more detail on this issue so we can continue to work towards getting this solved.
Thanks You
Jayhar.M.J
Helpful Links: Prepare your computer for download |  Autodesk Virtual Agent | Clean Uninstall | Steps for Setting-Up Student Software
Please Subscribe YouTube Channel
https://www.youtube.com/channel/UCclj8v9vHQiFa8_DriuAk3w
Message 3 of 9
vinodkl
I tried that but it still the same.
Message 4 of 9
jayhar
Which AutoCAD version you using??
Check UCS,
Set UCS in world
Message 5 of 9
vinodkl
I am using AutoCAD 2015. I already tried the changing the UCS to world. Its didn't resolve the issue.
Message 6 of 9
jayhar
Enter command EXPORTTOAUTOCAD> Bind > Yes > Filename > enter
it will save new cad file then try to trim
Message 7 of 9
vinodkl
That also didn't fix the problem.
Message 8 of 9
jayhar
just another fix, if you type "EDGEMODE" at the command line,
and set it to 0 (zero) that'll work too
Message 9 of 9
jayhar
Copy past to original coordinates in new cad file
