trim command not working
Message 1 of 11
hey!
i have recently downloaded autocad 2017 via student license and while i was using it, it came to my attention that the trim command is not working.
i mean whenever i try to use it, i select first my boundaries and confirm my selection by pressing enter but then there is never any line that can be trimmed.
i have used previous versions of autocad so i know how the command works but i don't seem to know how to make it work here. maybe it needs some extra add on or i can unblocked it in any way.
any ideas?
thank you in advance
Replies (10)
Message 2 of 11
Mark.Lancaster
@Anonymous
Welcome to the Autodesk User's Community..
This forum is used for installation and licensing issues of Autodesk products.  Not a forum to seek assistance of a given application.  Please use the AutoCAD forum for this.   I will have the moderator relocate your posting for the proper results
Mark Lancaster
Message 3 of 11
ennujozlagam
@Mark.Lancaster hello, this is an autocad forum. thanks Smiley WinkSmiley Surprised
Message 4 of 11
ennujozlagam
@Anonymous hello, try to install latest updates form autodesk ans see if helps. refer to this LINK. thanks
Message 5 of 11
Mark.Lancaster
@ennujozlagam
The posting was moved by the moderator..  Smiley Tongue
Mark Lancaster
Message 6 of 11
hey!
so i tried to install the update but the trim command is still not working
Message 7 of 11
ennujozlagam
@Anonymous hello, you already accepted as solution this issue?
Anyways :
Check your EDGEMODE setting.
thanks
Message 8 of 11
hello again,
i tried all the suggested solutions, i also tried to uninstall then install autocad but still nothing is working.
i also made sure that all my layers were unlocked.
any thoughts?
thank you
Message 9 of 11
Alfred.NESWADBA
welcome @Anonymous!
>> any thoughts?
Please upload your drawing with the objects that can't be trimmed.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Message 10 of 11
all lines can't be trimmed although it's a very simple drawing
Message 11 of 11
Alfred.NESWADBA
Your lines are as long as connecting 2 galaxies, that can't work as this is far beyond the double precision calculation accuracy.
E.g. one "short" line is > 20.000.000.000.000m long.
Scale your drawing (if that works) to real sizes and all works well.
- alfred -
PS: you know that DWT as extension should not be used to save drawing, please save your drawings using the DWG format?
Alfred NESWADBA
