AutoCAD 2017 keeps crashing with error code 0xc0000005
Hi there
We are running acad 2015 and the machine keeps crashing with the error code below. Anybody come across this error and have a solution
0xc0000005
 Allan
@Anonymous,
john.vellek has edited your subject line for clarity: ACAD 2015 keeps crashing
john.vellek
Hi @Anonymous,
I'm sorry you are experiencing this crashing with your AutoCAD 2015. is it fully up to dated?  What operating system is on your computer and is it up to date also?
I assume things have been running normally up to now. Can you check your latest Windows updates to see if some have just been installed and can be removed to fix the problem? You might also check to see if any drivers have also been updated.
When your AutoCAD crashes do you have the opportunity to submit a crash report? If so, can you send me the cer number so I can look up the crash information?
John Vellek
Hi John
Thanks for the reply.
i will check into the points that you have raised, but i do know that the designer was not given the chance to send an error report. He just received a message saying AutoCad had stopped working then shut down.
I will let you know how we get on.
Allan
My Apologies John,
I have just been informed that it is actually Autocad 2017 that is running on the designers machine. I will still get the info you enquired about
Allan
john.vellek
Hi @Anonymous,
Do you have an update on this issue for me? I would like to get this resolved for you.
John Vellek
Hi John
Sorry for the delay
We have uninstalled the following update
Windows 10: KB4041676 from all our machines as it stops us from running BOMs in Cadworx.
As far as i can tell Autocad 2017 is up to date on our machines too. What is the latest version?
Since restarting the program has been running ok
john.vellek
Hi @Anonymous,
I am glad that uninstalling the security update has restored your functionality.  I have found that the update updated one specific DLL that is causing the problem.  I am trying to determine a method to get this corrected easily.
The current updated version of AutoCAD 2017 is 2017.1.2 Update.  You can check for updates in your Autodesk Desktop App or in your Account page.
John Vellek
