trim command fragmented
When using the trim command, hitting enter twice for <select all>, the action does not trim lines all the way to the nearest intersecting line and acts as though EDGEMODE is set to 1. However, this is not the case and I am on a search to find out what other variable may be causing this issue. Example file with this problem is attached.
