trim command fragmented
jdfnnl
jdfnnl
When using the trim command, hitting enter twice for <select all>, the action does not trim lines all the way to the nearest intersecting line and acts as though EDGEMODE is set to 1. However, this is not the case and I am on a search to find out what other variable may be causing this issue. Example file with this problem is attached.
Brock_Olly
Is your trim mOde set to 'standard'?
trim > [enter] > O  [enter] > S  [enter]
jdfnnl
AutoCAD 2015 may not have the 'O' option after TRIM?
cadffm
You should say your software specs first (for the next time).
>>"When using the trim command, hitting enter twice "
So you type in TRIM and then you hit twice [Enter], the first to confirm "trim" input and start the command,
the second for <selectall>, okay.
I tested without a problem, please doublecheck your edgemode.
Screenshot of one of my tests. Restart Acad and try the same item&clickpoint on your side!
Edgemode 0 works as expected.
Sebastian
