Trim command crossing window not working
Message 1 of 9
I have been using the Trim/Extend command for 10+ years and I've never run across this problem. I am out of ideas so I am asking for help. The problem is when I use the Trim/Extend command it will not let me select multiple lines to trim or extend all at once. Instead it is making me trim or extend 1 line at a time.
Replies (8)
Message 2 of 9
Patchy
Try PICKADD
Message 3 of 9
Patchy - I tried PICKADD as well. Thank you for the suggestion. I've also made sure to check properties as well as options. I just cannot figure this one out.
Message 4 of 9
user181
Will it not allow you to make a window to select multiple objects?  If so check your PICKDRAG variable and try setting it to 2
Message 5 of 9
imadHabash
i suggest to change your PICKAUTO System Variable [ Initial value = 5 ] .  >> Click <<
Imad Habash
Message 6 of 9
GrantsPirate
If you have a newish version of AutoCAD perhaps try LTGAPSELECTION set to 1 ?
If your lines are not a continuous line type then this might be it.  Just a stab in the dark.
GrantsPirate
Piping and Mech. Designer
EXPERT ELITE MEMBER
Always save a copy of the drawing before trying anything suggested here.
If something I wrote can be interpreted two ways, and one of the ways makes you sad or angry, I meant the other one.
Message 7 of 9
vandenoosterkamp
wich release?
Message 8 of 9
GrantsPirate
Just type in that system variable name, if you have it then it will work.  I don't have my computer on to look up when that was added.
GrantsPirate
EXPERT ELITE MEMBER
Message 9 of 9
GrantsPirate
ThE variable LTGAPSELECTION was added in the 2017 release.
GrantsPirate
EXPERT ELITE MEMBER
