How do I display annotative text for Z (Elevation) for my points?
Message 1 of 9
Points.PNGI would like to show the contractors the elevation of a pad after shooting all the elevations on a job site. I'm able to import all of the points and the values, X,Y,Z are all present when I click on properties but, I'd like to display the elevation on screen. I attempted using blocks but, can only do one at a time. When I attempt to insert the same block over the point I shot, it duplicates my the first block elevation and changes the X and Y.
How can I display the elevation on the screen?
See attached.
Replies (8)
Message 2 of 9
Patchy
Message 3 of 9
It did not work. And, will this Display the actual points as well? Not just plot them?
Error:
Fields or delimiters missing in this line?1553.931,1247.835,-8.502
Fields or delimiters missing in this line?1532.802,1435.632,-9.208
Fields or delimiters missing in this line?1395.844,1428.632,-8.253
Fields or delimiters missing in this line?1037.134,1554.487,-8.335
Fields or delimiters missing in this line?1052.678,1772.623,-9.311
Fields or delimiters missing in this line?2292.790,521.675,-8.071
Fields or delimiters missing in this line?2076.962,416.311,-9.373
Fields or delimiters missing in this line?2156.371,670.418,-9.484
Fields or delimiters missing in this line?1943.845,582.876,-9.879
Fields or delimiters missing in this line?1796.154,579.503,-8.720
Fields or delimiters missing in this line?1795.513,579.115,-9.165
Fields or delimiters missing in this line?1358.073,518.903,-8.550
Fields or delimiters missing in this line?1195.208,541.066,-8.504
Fields or delimiters missing in this line?2041.344,691.381,-9.576
Fields or delimiters missing in this line?2253.454,761.141,-8.404
Fields or delimiters missing in this line?1380.030,3099.185,-10.389
Fields or delimiters missing in this line?1371.199,3381.130,-9.323
Fields or delimiters missing in this line?1147.847,3348.101,-9.503
Fields or delimiters missing in this line?1563.098,3202.907,-10.551
Fields or delimiters missing in this line?1721.419,3380.436,-9.749
Fields or delimiters missing in this line?1781.661,3489.934,-9.653
Fields or delimiters missing in this line?1998.832,3407.546,-9.304
Fields or delimiters missing in this line?1996.562,3316.342,-8.858
Fields or delimiters missing in this line?1833.082,3266.228,-10.433
Fields or delimiters missing in this line?1602.908,3268.444,-10.369
Fields or delimiters missing in this line?1381.502,3219.710,-9.748
Fields or delimiters missing in this line?1380.126,3031.447,-10.882
Fields or delimiters missing in this line?1592.065,3052.670,-10.644
Fields or delimiters missing in this line?1814.575,3032.725,-10.093
Fields or delimiters missing in this line?1819.781,2868.567,-9.652
Fields or delimiters missing in this line?1560.714,2830.900,-10.220
Fields or delimiters missing in this line?1335.629,2820.626,-10.119
Fields or delimiters missing in this line?1288.090,2623.595,-10.051
Fields or delimiters missing in this line?1576.977,2612.701,-9.712
Fields or delimiters missing in this line?1810.543,2582.444,-8.898
Fields or delimiters missing in this line?1810.077,2404.419,-9.495
Fields or delimiters missing in this line?1621.745,2371.840,-8.976
Fields or delimiters missing in this line?1371.110,2349.492,-10.101
Fields or delimiters missing in this line?1351.259,2453.459,-10.065
Fields or delimiters missing in this line?1300.387,2229.207,-10.704
Fields or delimiters missing in this line?1524.155,2224.995,-9.731
Fields or delimiters missing in this line?1810.847,2212.943,-9.290
Fields or delimiters missing in this line?1849.648,2101.172,-9.186
Fields or delimiters missing in this line?1615.336,2046.662,-10.088
Fields or delimiters missing in this line?1247.921,2014.945,-10.586
Fields or delimiters missing in this line?1292.301,1824.957,-10.280
Fields or delimiters missing in this line?1594.093,1829.994,-9.774
Fields or delimiters missing in this line?1941.501,1928.325,-8.991
Fields or delimiters missing in this line?1997.190,1739.649,-8.853
Fields or delimiters missing in this line?1796.069,1748.327,-9.935
Fields or delimiters missing in this line?1596.175,1708.866,-9.961
Fields or delimiters missing in this line?1303.128,1607.306,-10.545
Fields or delimiters missing in this line?1222.773,1694.269,-9.726
Fields or delimiters missing in this line?1340.397,1473.886,-9.209
Fields or delimiters missing in this line?1255.159,1218.128,-8.512
Fields or delimiters missing in this line?1061.470,1157.501,-9.096
Fields or delimiters missing in this line?1061.698,953.951,-9.720
Fields or delimiters missing in this line?1278.567,947.217,-7.543
Fields or delimiters missing in this line?1511.057,948.049,-9.885
Fields or delimiters missing in this line?1512.127,947.754,-9.543
Fields or delimiters missing in this line?1703.495,943.312,-9.210
Fields or delimiters missing in this line?1911.752,936.038,-9.731
Fields or delimiters missing in this line?2174.186,919.823,-9.507
Fields or delimiters missing in this line?2382.872,890.181,-8.729
Fields or delimiters missing in this line?2624.238,860.971,-8.736
Fields or delimiters missing in this line?2820.955,859.659,-8.819
Fields or delimiters missing in this line?2780.632,723.756,-9.088
Fields or delimiters missing in this line?2527.314,741.273,-7.919
Fields or delimiters missing in this line?2349.881,714.049,-8.020
Fields or delimiters missing in this line?2372.889,917.052,-8.889
Fields or delimiters missing in this line?2401.866,1099.740,-8.857
Fields or delimiters missing in this line?2415.746,1310.464,-8.212
Fields or delimiters missing in this line?2114.647,1365.419,-8.624
Fields or delimiters missing in this line?1982.642,1549.226,-9.176
Fields or delimiters missing in this line?1996.637,1726.261,-8.952
Fields or delimiters missing in this line?2193.473,1808.736,-9.430
Fields or delimiters missing in this line?2477.402,1817.332,-9.753
Fields or delimiters missing in this line?2520.330,1635.513,-9.385
Fields or delimiters missing in this line?2429.579,1533.776,-9.509
Fields or delimiters missing in this line?2681.983,1764.183,-9.842
Fields or delimiters missing in this line?2854.834,1873.239,-10.054
Fields or delimiters missing in this line?3201.228,1800.341,-8.579
Fields or delimiters missing in this line?3187.524,1656.770,-8.942
Fields or delimiters missing in this line?2938.096,1662.363,-8.957
Fields or delimiters missing in this line?2825.693,1544.669,-9.743
Fields or delimiters missing in this line?2624.731,1350.183,-10.445
Fields or delimiters missing in this line?2799.516,1151.806,-9.486
Option to put all point blocks on same layer is active. Search this text in the source code to change behavior.
"point.dwg": Can't find file in search path:
C:\Users\albert\Documents\ (current directory)
C:\Users\albert\City Concrete Corp. Dropbox\Albert Undercoffer\Mike Folder\Benedictine Sisters of Virginia\Surveying Software\
C:\Users\albert\AppData\Roaming\Autodesk\AutoCAD 2021\R24.0\enu\support\
C:\Program Files\Autodesk\AutoCAD 2021\support\
C:\Program Files\Autodesk\AutoCAD 2021\support\en-US\
C:\Program Files\Autodesk\AutoCAD 2021\fonts\
C:\Program Files\Autodesk\AutoCAD 2021\Express\
C:\Program Files\Autodesk\AutoCAD 2021\support\color\
C:\Program Files (x86)\Autodesk\ApplicationPlugins\Autodesk AppManager 2020-2021.bundle\Contents\Windows\
C:\Program Files (x86)\Autodesk\ApplicationPlugins\Autodesk AppManager 2020-2021.bundle\Contents\Windows\2021\
C:\Program Files (x86)\Autodesk\ApplicationPlugins\Autodesk FeaturedApps 2020-2021.bundle\Contents\Resources\
C:\Program Files (x86)\Autodesk\ApplicationPlugins\Autodesk FeaturedApps 2020-2021.bundle\Contents\Windows\2021\Win64\
C:\ProgramData\Autodesk\ApplicationPlugins\Beardyugin Coordinate_Import_Export.bundle\Contents\Resources\
C:\Program Files\Autodesk\AutoCAD 2021\drv\
*Invalid*
Cannot invoke (command) from *error* without prior call to (*push-error-using-command*).
Converting (command) calls to (command-s) is recommended.
Command: POINTSIN
Select a file format:
1. PNEZD (comma delimited)
2. PNEZD (tab delimited)
3. PNEZD (white-space delimited)
4. PENZD (comma delimited)
5. PENZD (tab delimited)
6. PENZD (white-space delimited)
1/2/3/4/5/6: 4
Fields or delimiters missing in this line?1143.659,2226.342,-10.141
Fields or delimiters missing in this line?1361.823,2304.687,-9.409
Fields or delimiters missing in this line?1270.133,2583.886,-9.816
Fields or delimiters missing in this line?1244.933,2917.387,-10.052
*Invalid*
Message 4 of 9
Patchy
Like this?
Message 5 of 9
You should be able to do this by:
1-Create point label style that shows the elevation of the survey shot as you want it.
2-Create surface of survey shots and label spot elevation randomly (you pick the point where the label goes), or on a grid.
C3D objects behave annotatively.
In either case if you have to share the drawing with non-C3D user, export the C3D dwg to AutoCAD and you'll get blocks instead of cogo points or labels. I'm not sure they'd be annotative blocks, but you could BURST them to be left with text which can be anno text.
Message 6 of 9
Yes, just like this and, all of my points at the same time. Were you able to that simultaneously?
Message 7 of 9
Patchy,
How did you do that?????
Message 8 of 9
Patchy
Use the point data you already have, follow the instruction from the link provided and use command POINTSIN,
choose the comma or space delimited and let it do its work.
(I don't have your data so I exported your points as xyz then used that POINTSIN autolisp)
Message 9 of 9
Thank you!!! It worked. I didn't realize I had to copy and paste the POINT block into my drawing and create a new point. Once I did that, it worked!!
Thank you.
