Transparency level of dimensions line
Dear Friends,
        I need to decrease transparency level of dimensions line, and i have to fix that in one place. that may be in dimensions style or others. how do i fix. please help me.
Alfred.NESWADBA
open the layer manager (command _LAYER), select the layer on which the dimension object was created and define the transparency value there.
May I ask why objects (without fillings, just lines) need a transparency? If you want to have them lighter the solution would be to give them a lighter layer color.
HTH, - alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2026
(not an Autodesk consultant)
avminkler
I was also looking for something like this.  The lightest line weight is still too dark in my opinion as I use that same line weight for other items as well.  I'd love the dimension lines to appear "ghosted" as if they were a faded drafting line.  Setting the layer transparency that they are on though just makes the entire dimension transparent instead of just the extension line.  I could always just draw the extension lines manually and have their transparency set lighter, but that's just a lot of unneeded drafting coordination.  It's a great "wishlist" item...
S.Faris
Inorder to achieve what you need, you can reduce the Screening value of the respective color inside the CTB. See below example
MODELSPACEMODELSPACEPDF OUTPUTPDF OUTPUTCTBCTB
SALMANUL FARIS
avminkler
That is a great idea!  I'll have to give it a shot.  I've forgotten about screening ever since transparency came around...
