Touch point along two 3D objects
Dear forum,
I have drawn several railings in Autocad, in particular a non-standard spiral railing (i.e. not aligned along a circle or ellipse). This railing needs posts, so I have drawn the requested position of the railings posts on the floor plan (yellow rectangles, after generating the touching points "visually"). But now, of course I need the railing posts to touch the railing at two different points, in particular, the hand rail needs to be touched by some part of the posts (see attached DWG-file).
I just moved the railing posts along the z-axis and inspected the most likely touching point visually as already mentioned. But this, is after all, if I send the data to the manufacturer, not very satisfying.
Does someone have an efficient and effective way to reach a satisfactory result with more sophisticated means ?
Thanks a lot!
