Custom Autocad Properties Import to Dynamo
james_fisher1
james_fisher1
Does anybody know how to read properties from an autocad object into dynamo?
For reference, I’m trying to import an object into dynamo that was originally a shape file. Hence, whilst it is technically a poly line, in practice it has several custom properties that don’t otherwise exist in cad.
Specifically looking at the OD:EXISTINGCOMMSLine properties from the attached image.
  • This file was provided to me by another user. I think the attribute is probably part of a Property Set, but I don’t understand why it is appearing under design instead of Extended Data, and I think this is probably part of my problem in reading the data. For Reference, dynamo says that no property sets exist in this file.
Udo_Huebner
MAPIMPORT attach Attributes from SHAPE File as OD (Object Data) in AutoCAD MAP / Civil 3D.
ACA / MEP and Civil 3D uses for AEC Object Attributes  as PSD (Property Set Definitions).
You can use Object Data in Dynamo as well.
https://www.youtube.com/watch?v=pTg4I_eE2FQ
Gruß Udo Hübner (CAD-Huebner)
