TORIENT COMMAND NOT WORKING
AutoCAD 2019 is giving me this message whenever I try to use the TORIENT command:
Command: TORIENT
(*pop-error-mode*) underflow.
Cannot invoke (command) from *error* without prior call to (*push-error-using-command*).
Converting (command) calls to (command-s) is recommended.
What should I do?
MMcCall402
Yea, this happens sometimes. Save the drawing, exit AutoCAD and reopen.  Something goes wonky and you need to close up shop and reopen fresh.
Mark Mccall
CAD Mangler
VHB - Engineering, Inc.
Thank you! That worked!
jayhar
your same post here https://forums.autodesk.com/t5/autocad-forum/torient-command-not-working/m-p/8559071#M966023
you need to check any error in autocad, this time its solve again and again it repeat because your error already shown
Also you didn't give replay in this post
first confirm no error in AutoCAD.
Thanks & Regards,
JAYHAR.M.J
Detailing Engineer
CICON Rebar Solutions Pvt. Ltd.
DD Trade Tower, Kaloor-Kadavanthara Road,
Kaloor, Ernakulam, Kerala,India - 682017
E-mail : jayharcicon@gmail.com Mob : +91-9961032444
Issued by Autodesk
Please Subscribe YouTube Channel
https://www.youtube.com/channel/UCclj8v9vHQiFa8_DriuAk3w
Please Mark the Post or Posts as Solution(s) to help others find the answer quickly.
